Subwoofer Problem....
Slammed
Striking Accord
I just bought a Dayton DVC subwoofer
I hooked it up fine...parallel
I mounted it inverted (long story)
it sounds amazing inside the vehicle...it gets louder than I actually want it to be.
problem is, when I open my trunk the sub rattles. The sub is brand new and its receiving 700-800 watts RMS witht he gains down and bass boost at zero (as always). Sub is conservatively rated at 600 wrms.
It started making this sound as soon as I hooked it up.
what could it be?
thanks
Since you have the sub inverted...it could just be a little bit of mechanical noise.
Check for airleaks, as you mentioned.....other than that, try playing it free-air and see if it still makes the noise. If it does, try to narrow down where the sound is coming from.
So....other than the rattle, what do you think of it so far? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
bass goes low man.....SQ is great, but, when I play it loud I can hear the rattle a bit.
louder than the 12" SE I had before (from 50 hz. and up)
the SE actually hits the lower notes with more authority.
I have it in a 3.2 cu ft vented enclosure tuned to 29 hz
Squeak...do you know if air leaks can damage a sub?
I'm going to have to agree with Brad on this one. Sounds like nothing more than a mechanical noise. They have a 5 year warranty, so why sweat it.
And BTW, just for your information, your precious Steelers will be the ones getting pwnd this weekend.
thanks
and....we'll see about my Steelers
all we need is one mistake from you guys //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Slammed
Striking Accord
Slammed
Gotham City, NY
Pyro_By_Nature
Mike Mccabe
