Slammed
Striking Accord
Lets say I have a Class D amp that puts out 200 watts RMS @ 4 ohms
I want to hook it up to a sub that is rated at 350 watts RMS but with a sensitivity of 96db (2.83V @ 1m)
...and its going into a 1.8 cu ft vented box (after displacement) tuned to 29 hz.
will this subwoofer reach its full potential?
Power Handling, RMS 350W
Sensitivity 96dB (In car) (2.83V @ 1m)
FS: 23hz
Re: 4.0 ohm
Le: 3.05
Qms: 10.28
Qes: 0.46
Qts: 0.44
Vas: 99.97 liters
Sd: 531 cm2
BL: 16.90 tm
Xmax: 14.1 mm
Thanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
FS: 23hz
Re: 4.0 ohm
Le: 3.05
Qms: 10.28
Qes: 0.46
Qts: 0.44
Vas: 99.97 liters
Sd: 531 cm2
BL: 16.90 tm
Xmax: 14.1 mm
