subwoofer hit to hard
caliece
hi i got 2 15" subwoofers that can handel 500rms and 1500peak each. 1000rms pair and 3000peak pair and i wanted to know if i run them a little over their rms will they still be ok thinking about a viper 2500.1 //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
but just found a concept cc-d1200 going to run it at 1ohm at 1200 watts that should be ok but how do you use the dmm what do i put it on and how to use it? really need to know thank you guys
Been a while since I looked at the 2500.1, BUT, they do put out 2.5kW@2ohms, soo if your drivers are sriously rated @ 500wrms, I think a 2500.1@2ohms would be a little too much.
ok thanks but how do i use the dmm and what type should i get also why do the gains matter any way how come you cant just turn them all the way up
why do i have a feeling hes talking about type-r's and if you turn the gain all the way up on the viper im going to laugh at the results....
hell they can handle it i am giving my type r 600rms and it calls for 500
//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif WOW 100w RMS OVER the suggested RMS??>>!!! WoWZERS You ARE L337 BEYONd BeLIEF
Anyway.. He never said he had the R's.
I have an amp that will do 1250w @ 1 ohm if you are interested, and double a speakers RMS rating is never good to do unless you have some experience.
thanks alot you all were alot of help
DMM's come with directions... get a fluke... well that's what i like and i've never had a problem with them... if the gains didn't matter then there would be no such thing.. i'm sure i could explain more... but you wouldn't understand... http://www.bcae1.com go there and start reading... you shall learn a lot young grasshopper
caliece
caliece
chicago il
caliece
