Convoy
I am pretty much stumped and have read and tried almost everything, I really need some help. My Subwoofer is not working correctly, it cuts out or "Clips". Not really at that high of volume, and it is rather quiet even before it cuts out.
My Setup:
2001 Mustang GT with Mach 460 package.
Head Unit: KDC-X891
Amp: KAC-X10D - Class D Mono Amp (1 Ohm Stable) - 1200 Watts Max
Subwoofer: KFC-XW1212DVC - 1200 Watts Max - (Dual 2 Ohm Voice Coils)
Bass Knob: KCA-WR10
I have it wired for Parallel and a 1 Ohm load as per the diagram that came with the sub.
More info and things I have tried:
I tried twice to wire it Series for a 4 Ohm load but the problem persists.
I have checked the ground and tried different bolts and sanded the paint off and checked connections.
The amp power wire is connected directly to the battery with a 60amp fuse under the hood.
I tried turning down the input sensitivity on the amp and with my kenwood bass knob and in the head unit.
I checked all wires for shorts/kinks of any kind and found no problems. I bought a wiring kit with 4 gauge power/ground.
I connected my sub to a friends system a couple weeks ago and the sub worked perfectly until we blew his large fuse, most likely due to the fact that we didn't re-wire my sub and his amp is not 1 ohm stable.
Also I might note that when it cuts out the light on the amp will dim or blink but will not go out permanently as if protect mode was activated.
I will also say that I installed this myself with the help of someone who knows more and that day everything worked fine and the sub hit extremely hard with no problems even at high volume. And to my knowledge nothing has changed since except the performance.
I have had this problem for a long time and even created a thread in 2008 but didn't get much response so I gave up until now. I am beginning to wonder if this is a defect/characteristic of the amp or, because it worked at one point, something may have broken, but upon inspection of the amp and the speaker, they look perfect.
If you have any other questions about my system feel free to ask. I can post pictures if that will help.
Any advice or ideas would be greatly appreciated!
Thanks,
Convoy
My Setup:
Head Unit: KDC-X891
Bass Knob: KCA-WR10
Thanks,
Convoy
