Subwoofer Configuration Question
every sub you series is doubled per coil/sub(if svc)...say dual 1 in series is 2...2x1=2
every sub you parallel is halved per coil/sub(if svc)...say dual 1 in parallel is .5... 1 divided by 2 = .5
every sub you series is doubled...say dual 1 in series is 2...2x1=2
every sub you parallel is halved...say dual 1 in parallel is .5... 1 divided by 2 = .5
parallel is not really halved. It is divided by number of subs
series is simply adding coil+coil+coil, etc
4 1 ohm coils parallel is .25 ohm 1/4 = .25
4 1 ohm coils series is 4 ohm 1+1+1+1 =4
3 8 ohm parallel 2.66 8/3 = 2.66
I dont see where my math is incorrect. I know there is more involved when you have differening values but that should never be the case in this application
nativeboy
PIMPING JOKER
nativeboy
Flagstaff, AZ
Upgrayedd
