Subwoofer/amp/battery wiring assistance needed.
todj
Mr. Knowledge
Okay I have a dual 2 ohm subwoofer that I want hooked up to my 4 channel amplifier. I am not sure how to wire it to a 4 ohm load. Also, I was wondering if I need an isolator to hook up two batcaps and a battery in-line with my power cable or if I can just run it direct.
This would be easier if you posted the specs for that amp, I'm not in the mood to track them down myself just to help you.
But the main thing is, yes it's possible, if you wire one voice coil per channel, but that would end up a 2 ohm load on each channel, and I kind of doubt you can bride all 4 channels together...
Stereo, 4 ohms:
Stereo, 2 ohms:
Bridged, 4 ohms:
Special Order 2 ohm Version
Bridged, 2 ohms:
T.H.D. + Noise:
Frequency Response:
S/N Ratio:
Transient Distortion:
Slew Rate:
Damping Factor:
Input Sensitivity:
Dimensions:
4 x 300 Watts
4 x 600 Watts
2 x 2200 Watts
2 x 2200 Watts
20Hz - 20KHz, + 0dB / -0.28dB
>85dB
>20V/uS
>225 @ 4 ohms
250mV - 16 Volts
19.5"L x 8.75"W x 2.375"H
todj
Mr. Knowledge
todj
Reno, NV
todj
