Subwoofer Advice
Cxrazy
Hey guys.
I know a bit about subwoofers, but apparently not enough.
Basically this is what I want: One 12" subwoofer around 400W RMS. I'd want to spend ~$100. Lower if possible, but if thats not possible alright.
I don't want anything super awesome expensive, just something that is a great value, has great SQ, but can get LOUD if I want it too.
I'd build the box myself, ported probably around 2cuft try to tune it down to around 25-30hrz.
I'd really appreciate all you sub guru's advice! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Since I don't necessarily know what brands make good value stuff, and I tried looking around on this site, but its really ocnfusing jumping into all sorts of model numbers and stuff.
Thanks! //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
I like your avatar!
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Anyone else have suggestions?
I like how the AQ's are looking.
Would the 350W RMS amp be enough?
Also, is there a good box design already laid out that I could just build that would suit my needs? (~2cuft ported, tuned to ~30hrz)
definately they are very efficient and can take alot more assuming everything is done right
and they control the cone very well so good sq
not a sq sub but sound very good and get loud
but if we get into this what is an sq sub,, its so user variable
I found one of the free boxes that I can make work for sure.
How many ft^3 does a single 12" Audioque S2 take? I cant find it on their site...
Which one would get louder on 350W, the Maw-12 or the Audioque SD212?
The AQ looks like a single coil 4ohm(hard to find specs on the site) and the Maw looks like dual 4ohm. So...
the SD 2.5 a look like dual 4 and have more useable xmax than the SD 2.
Not sure which would get louder, seems like you would be pretty set with either, though the AQ does look like a beefier motor structure. Both are pretty hard hitting bang for the buck.
Aq specs are on the order form.
I actually just bought a 650x1 @2ohms and 950x1 @ 1ohm
Still looking for 1x12" Still looking for same price range, but handle more watts. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Cxrazy
Cxrazy
Tulsa
Cxrazy
