Pl8er
Can you solve it?
With the VR2000 you can just bypass the capacitors by just taking it out and soldering the connectors together from the bottom of the blown capacitor. That's the nice thing about Crossfire amps. If you need a step by step just let me know. Crossfires can be used with a blown capacitor, and actually produce more wattage this way. If you've ever heard of "cheater amps," they use the same concept. Remove a capacitor, solder wire from where the capacitor was, and voila... you have have 15-17%% more wattage.
This, but you are missing one of the key reasons behind the benefit. The capacitor's job is to store energy thus allowing for quick surges of power to the rest of the amp. By removing the capacitor you are actually allowing the amp to 1. run cooler (you don't have the heat of the stored energy) 2. not require as much amperage to produce the same and as stated, more power (the heat I discussed actually is energy dissipating). It is very important to use either speaker wire to make the bridge or a copper bus bar. Only use monster wire if you are going the speaker wire route, it is the only kind that i have found that can hold that kinda power without heating up. Cu bus-bars are my personal choice though.Plus it gets rid of the distortion that the caps add. Since the power has to go through less components, it has less chance for those "missing" components to add distortion.
So you will get more power, that is cleaner.
