alright I'm about to get back to it just wanted to check one thing first Im gunna go with a 4 ohm load since I don't want to much bang back there so..the diagram shows I need a wire comming out of each sub on the - and on the + then wired together going to the amp..if I connect the = and - to the terminal on the back of the box then run a wire connecting the terminals on the outside of the box. add a second wire from one - and one + terminal going to the amp will that be alright. I was thinking I needed to connect the wire inside the box from speaker terminal to speaker terminal and only have one wire comming out the back but its all the same isnt it?
