- Thread Starter
- #16
[quote name='shredder1']This is what I came up with...
I have a question If I may ask... should I adjust the port length until I match his measurements with the physical port length?.. as you see there is a discrepancy in the "Port length" and "Physical port length".. I adjusted one to meet his measurements as I believe it may be "seeing" the length differently... OP, yes I'm still learning the finer points here... if not it is tuned to 47 hz or so... @Jeffdachef[/QUOTE]Thanks....that's definitely higher than I would like. I adjusted the sonic filter higher to match closer and it definitely doesn't have that deep hit I want.
Sent from my SM-G935V using Tapatalk
