Subs stopped working - Need help Diagonse
munchy_cool
38
7
FL
Hello All,
Yesterday while I was driving the subs on my pony stopped working.
Setup I have
  1. Aftermarket Sony Head Unit
  2. 2 Soundqubed HDS208's in a T-line box made by CSCStang
  3. Pioneer GMD9601 Amp, with Bass Boost remote installed and working
Things I have checked
Fuse under the hood for continuity - all good
the 3 fuses on the amp for continuity - all good
Checked the voltage at amp terminal - its >14 volts
Light on amp is solid blue, not red or blinking red so I guess its not in lockdown mode.
Increase the bass using Bass Boost knob, still no sound from subs
Subs are flexing when pushed with bare hands
Assumptions after above test
Fuses seem good
Amp is getting enough power
Subs do not have a stuck coil or something
Things which could be wrong
Amp is not throwing any output to the subs
Amp is not getting sound input from the head unit
Subs wiring has gone bad
Questions
How do I check above 3 things with a multimeter.
Any other things I should check
Use a 3.5mm to male rca adapter and plug your phone/ipod directly into the amp, bypassing the hu. If it plays, there's an issue at the hu. If it doesn't it's the amp.
Sent from my SM-N920V using Tapatalk
gotcha ..any stores which would carry that cable?
Yessir
Sent from my SCH-I605 using Tapatalk
not sure what happened ..
On my way to and from target, music system is playing , no bass.
I come home, park, still no bass..plug in the new Y cable into the amp (using my phone), 10 seconds later .we have bass...it vanishes again for 5 seconds and is back again.
I plugin the head unit input and all is well again, bass is back //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Question though remains, is something going wrong with the amp? or it was just a one off thing. I did turn the car off a few times and played music again with everything working fine..Is it a bad connection somewhere? Anything else which I should double/triple check?
Could very well be the rcas
now that you say, i do remember pulling those guys a little bit ..I guess its time to change those, which brand do you recommend?
munchy_cool
munchy_cool
FL
CSCStang
