- Turn your bass boost all the way off, turn your remote gain all the way up and your HU sub level all the way up, if you have the LPF set on your HU run that around 63 or 80 and turn the LPF on the amp all the way up, if no LPF is set on the HU then set it to about 80hz on your amp, zero out your EQ, loud off, 3/4 volume and then set your gain, you shouldn't need more than 1200 - 1500 for a daily setup though //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Try that and check again, they are normal to bui;ld up some heat and get warm / hot after hard use, but not to the point they are going to melt lolSo you think maybe it would be safe for me to crank these subs back up to 1600W where I had them? Cuz that's what I was running them at before I felt them that hot, then I was like "uh oh, too much". But if it's normal for the SA line to get that outrageously hot and still perform fine then alright.....also if the subs continue to get considerably louder with each bump of the volume does that mean they are still NOT clipping or at risk of burning up? Or is that just a myth? Cuz when I was running them hard the other night they just kept getting louder and I kept playin em till I felt how hot they were and it scared the be-jesus out of me haha.
