So, i got two Sa-8's DVC wired at one ohm. ( their 4 each). I checked the wiring before the install and got 1 ohm resistance so i assume their hooked up right. Only one works and its hooked the the other sub. What i mean is their is two bolts on the box. the wires that run from that go to the messed up sub. Then, wires go from that sub to the next. Im not sure what to do. Do i start setting gains and see if it begins to work? Do i send it back? Its a brand new Sa-8 from Amazon.
