Subs keep blowing.
I suspect they are blowing because they are complete garbage and the amp isn't far behind. Like buying a pair of 40$ work boots. You'll go through 8 pair of them before I wear out my 200$ pair.
There is nothing you or we can do to make that amp put out anything close to clean and rated power, and even assuming you give the subs clean power they likely have about a 30% failure rate right out of the box.
Hate to agree cause its kinda harsh but... Agree with this. Change out your amp.
throw everything in the garbage and start over.
1500wrms on 70A fuse, man I hate these lying ass companies.
and people dog on me when I mention cea compliancy.....
yea hate to say it but everyone iv known to by boss learned quick, i mean comon you can get a so called amp rated for 5000 watts which i would doubt it puts out half that for a 100 bucks somethings not right. and i would almost guarntee the subs cant handle the rated power.not trying to hate but you live and learn.i would try and sell them for what ever you can get.and normally i would say check reviews but iv seen thiers and whoever bought it and said great buy is fuc***g retarted.and yes subs are not pickey on ohm load amps are check your wiring again and then double check,i really dont see your amp going into protect from an 8ohm load but if its is in one ohm probably.and also what size wiring do you have.
WHAT!? Subs aren't picky about what load is going through them. The wiring resistance of them determines the load the amp sees. If he has them wired wrong he may be putting out a load the amp doesn't like, but the coil of the sub only cares about how much wattage it is seeing.
im talkin about this sub not subs in general.. iv actually done a fair amount of research on these an everyone says they destroy themselves running at 1ohm
Heat or exceeding mechanical limits are the only reasons a sub will blow. Impedance has 0 to do with it. All these subs were either being over-powered/clipped or bottomed out.
Dont set it to the 1500 is says it does. Set it to the 700 it might do
I don't understand what you mean by this post.
Wow. I had to read that like 3 times just to understand what you were saying. Try using the spacebar, correct punctuation and capitalize the first letter of a sentence.
He's saying read the guide on how to set your amp. Part of the process is knowing how much power your amp puts out in rms power. That amp claims to put out 1500 rms, it actually puts out half of that probably. So in the gain set process, you would set it using 500-700 wrms because that's all that turd can do.
again im sayin from what iv heard from at least 5 people say "these" subs even at lower power fail at 1ohm
No.... no you didn't. That doesn't even make the littlest bit of sense, and the odds that 5 different people told you that is astronomical.
You made that **** up didn't you?
jcrom95
jcrom95
Willowick
Better-Action
