Subs just cut out
2008screw
Hey all,
I'm cruising along and my subs just stop working.
I checked the amp, it has power
I checked the speaker wire. Looks to be all connected.
What else can I check? The mids work great and I have not touched anything.
You help and insight is appreciated.
my friends used to turn off when he would have them up all the way up, either not enough of power in battery or alternator
also chek your fuses. On the inline fuse, amp, and any factory fuses that might be related to it. Make sure you arent shorting to groundon the amp. No frayed wires.
Is the amp in protect?
Make sure your ground is secure
also chek your fuses. On the inline fuse, amp, and any factory fuses that might be related to it. Make sure you arent shorting to groundon the amp. No frayed wires.Is the amp in protect?
If any fuses werre blown, then would there not be any power getting to the amp? The amp still lights up (the alpine blue)
2008screw
2008screw
Vancouver, BC
2008screw
Mike Mccabe
