Subs in a 94 tercel HELP!
MacDre
Alright, so I have a 1994 tercel and the audio system is completely stock (crap). So over the past few weeks I've been buying stuff for a new system. So far I have a new alpine deck, 4" alpine speakers (front doors), and 6.5" alpine speakers (rear). So now I've hit a snag. I'm not sure if I want two 10" subs or two 8" subs. I want the 10's but I don't want my car to rattle down the street lol.
But I've found what I think is a pretty good deal and I can get two Alpine SWS-1023D for about $160.
The specs are as follows:
* 900 watts max output
* 300 watts RMS (150 per coil)
* 10" sub
* Extra reinforced pulp cone with aluminum finish (Rev-lar made for long lasting sub)
* 3/4" rubber surrounds
* dual 2 ohm voice coils (you can run at 1 or 4 ohms) (2 subs @ 2 ohm or .5 ohm)
* stamped steel basket
* frequency response 30-700 Hz
* sensitivity 84 dB
* top-mount depth 4 3/8"
* sealed box volume: 0.65-1.5 cubic feet
* ported box volume: 1.0-1.75 cubic feet
So my question is this should I get those two 10's for a 1994 tercel, AND PLEASE recommend amps to power the things.
Go with the 10's aim them forward and seal the rest of the trunk off from the inside cabin. That should keep them from rattling. A small class d around 500 watts will work just fine (whatever brand you can find cheap they are all pretty much the same now any way).
Alright I've decided on the 10's
So I need a amp that will power these specs x2 (two 10's)
* 10" sub
* sensitivity 84 dB
Please leave info on the specs I will want to look for on a amp to power this...
MacDre
MacDre
LA, CA
MacDre
vegang
vegang
