SUBS help
You should post up the model # of the sub and or the number of voice coils on the sub. Sometimes it is easy to extrapolate what you have by the description but many times if the driver is an older model it may be quite difficult to find the appropriate info on it.
If those subs are single voice coils, more than likely you'll only be able to take the impedance load of the amp to two ohms which will give you 600 watts from that amp.
If this is the case I would say that amp would be perfect. I think those subs are a little over rated on their power handleing.
It's always better to run more power than needed as opposed to not running enough.
You are in control of the volume knob...
Just another opinion...
yeah, pay attention to the bold...hahaha. ANYWAYS, i personally would not buy that amp for those subs. It is a GREAT amp...but with the subs you have...i would be afraid of overpowering them AT ALL. now, if u buy that amp and sell ur subs to buy new subs....then u'd be great. Like better higher quality subs...also chances are there are other amps that will give the same power as the kicker and be cheaper.
check out:
amps:
http://www.avionixx.com
http://www.thezeb.com (us acoustics and profile)
check out other sites for us acoustics, cheaper prices on kicker, orion, planet audio, etc.
subs:
http://www.stereointegrity.com (one magnum d2 would kill those JVC's)
http://www.respl.com (2 12" se's or one 12" XXX would kill the JVC's)
http://www.edesignaudio.com (2 12" K's, or one 12" A)
http://www.incriminatoraudio.com (2 Lethal Injection 12's)
good luck, peace
NG
JMOCK
JMOCK
Auburn, ME
jlsnydertyper
