subs fighting eachother
ballinplaya
my friends subs are in a box and in front of the subs there is plexiglass or some kinda hard plastic and like when they hit they go different directions, one goes in and one goes out like they are fighting eachother. what exactly is happening? why does it do that?
thanks,
Derrick
i thought that was normal. All the subs i've seen one has gone in while the other goes out, and i always thought that was just a normal part of subwoofers....is it bad for them to be out of phase?
And in some cases, if the sub is in a completely diffent chamber altogether...
I had my SE 15 up all the way and it moved the JL 12w2 that I was transporting almost 3/4 an inch :)
...and i just brought back a thread that was a year and a half old :)
if the 2 subz are 100% opposate in firing it means you have one of the subs wired backwords, just switch the polarities for one of em, it doesnt matter which and this will be corrected, when they do this they should almost intirely cancle eachother out
another idea is that you have the subs wired as right and left channel and your deck is distributing right and left bass and for some reason there different.
or if one sub is dead then the air will move the other in and out
always best to buy a box with seperate chambers
not necessarily, you just cant have your subs out of phase from each other even if they are in separate chambers its not a brilliant plan
not a terrible plan eather considering it wouldent change anything affecting phase, i didnt mean that in the sence that it would fix his problem, i ment it as its easier to work with and its easier to figure out what the problem is in the first place
...my dad has a 99' SHO
bah!! v8 sho's ****, you only gain a few HP, lose torque, and gain a lot of wieght from the older v6 ones...and you cant get a 5 speed...gay!!, but its cool that someone else on here knows someone that has an SHO that is not even related to mine at all.
sorry, its past my bedtime //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
ballinplaya
ballinplaya
Midwest
hoss
