subs dont work:( someone HELP!!!!!!
stratastic
stratastic @ DI.net
ok heres the problem when i turn on the deck the amp power light comes on but doesnt play. i know i have everything hooked up right. ive tried changing all the wires and changed the deck, still doesnt work. i know the speakers are good and the ohm load isnt to low. ive installed quite a few systems and this is the first and only one ive had a problem with.
IM CLUELESS:mad: //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif :mad: //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
someone please help
thanks in advance for any help
NICK
check the settings on the deck,gain, and see if theres voltage at the amp wire terminals and all around, ground main power etc. also check voltage at box terminals.
everything is right but i still dont have a clue
it all worked until i fried a amp about 2 months ago
i even tried taking all the wiring and speakers out of my friends car and i even replaced the HU thinking it could be bad rca's but the problem still exists
i want bass back in my car soo bad
im taking it to my local audio shop on thurs but was hoping i could get some help on here before i have to spend alot of money
If you KNOW that the amp is getting power, remote, audio signal & is wired correctly then you have either a bad amp or a bad sub. Most likely something's not wired right tho.
Sometimes when you've been over it 1000x you miss the obvious stuff - we all have!
Try to hook another sub up to the amp in ur car that u know works.
if it works it the amp.........
or Hook another sub up to ur amp that u know that works and if it works its ur sub.......
stratastic
stratastic @ DI.net
stratastic
sycamore, IL
KidThump
