subs cut out
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif:rolleyes://content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif:rolleyes://content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif:rolleyes://content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
go set your levels and come back and tell us how it went and worked out for you. It only takes about 10 minutes.
wow take the intrawebz too srs
joo wantz to trayde hanjobz?
WTF?...****ing ***...im outs!!..//content.invisioncic.com/y282845/emoticons/escape.gif.52b661afb17bde1db0e0c7da97e75b38.gif:escape://content.invisioncic.com/y282845/emoticons/escape.gif.52b661afb17bde1db0e0c7da97e75b38.gif:escape://content.invisioncic.com/y282845/emoticons/escape.gif.52b661afb17bde1db0e0c7da97e75b38.gif:escape://content.invisioncic.com/y282845/emoticons/escape.gif.52b661afb17bde1db0e0c7da97e75b38.gif:escape://content.invisioncic.com/y282845/emoticons/escape.gif.52b661afb17bde1db0e0c7da97e75b38.gif:escape:
what setting are you guys using on your dmm?
I used it and set it to .489.....etc and it was at 3/4 volume [26/35]
it still does the same shit.
my bat voltage at the amp is 12.3
and who cares if this setup isnt the best?
ive most likely have an amp thats way better than yours. you're rocking some hifonics ebay special amp. ive got a pg xenon 1200.1 so keep running your mouth. this is just a temporary setup till i build my box for my audioque sdc 12's
allright so i turned the gain to normal, actually a little under. I can play a few bass notes @ high volume, but then the subs just make a popcorn noise...a lil hollow pop and then cut off. lpf on the amp is set 1/2 way up, prolly 80hz-100 hz or so
i cant have it wired too low because they are SVC subs. a retard could wire up svc subs.
i wired them also to 8 ohms and it still does it
grooverider
grooverider
IL
grooverider
michigan born
    May 14, 2026
michigan born
    May 14, 2026
