Subs are cutting off, Can someone help me please?
kingbrew06
I've been running 2 kicker 4ohm CVRs and 1 mtx 4ohm blue thunder with a 2000 watt mono boss amp. The mtx blew so i went and bought another kicker, hooked it up just as the mtx was hooked up, and now, the subs are cutting off after 10 seconds of playing. The amp isn't hot. I need some help if anyone has some time. Thanks!
they are wired parallel. and that are also 10s. The come on and are hitting hard, then after 10 seconds or so, the subs cut off, but the music still plays on my speakers.
not sure on the amp my dog tore up the **** box and the papers ill find out hold up and to the other guy the box was built for three tens to run parallel i started with three mtx 4ohm 300w rms subs but they were used and glued together so it was ****ed up as they blew like i knew they would i bought kicker cvrs and put one in at a time tryin to get the most out the old subs now its three kickers one box one amp.
MONOBLOCK MOSFET POWER AMPLIFIER WITH REMOTE SUBWOOFER LEVEL CONTROL
MAX POWER, 1 OHM
n/a
MAX POWER, 2 OHM
2000w x 1
RMS POWER, 4 OHM
500w x 1
MAX BRIDGED POWER, 4 OHM
n/a
SIGNAL-TO-NOISE RATIO
> 105 dB
THD
0.01%
DIMENSIONS: 11-7/8”W x 2-5/8”H x
16-13/16”L
CHAOS EXXTREME MOSFET MONOBLOCK AMP FEATURES
· Remote subwoofer level control
· Line and speaker level inputs
· Variable gain control
· Input sensitivity selector
· (CX1100M only)
· Variable lowpass crossover
· Power and protection LEDs
· 0-+18dB variable bass boost
· (CX2000M only)
· 0-+18dB selectable bass boost
· (CX1100M only)
· MOSFET power supply
the stats on my amp
kingbrew06
kingbrew06
nashvile'tn
subzero
