Why does my amp turn off
3) 13.5 JL w6v2 and d.e.1000.1!?!?!?
i know my wireing to my subs are correct its not very hard lol! im thinking low volts if i do a big 3 upgrade will that be good?
i want it to stay on the main log cuz i need to know asap im thinkin low volts..... idk amp is wired and runs fine at lower volume below 25.... but then after that shuts off and im scared to try it so i dont blow a fuse in my amp... whats do you think ...
3) 13.5 JL w6v2 and d.e.1000.1!?!?!?i know my wireing to my subs are correct its not very hard lol! im thinking low volts if i do a big 3 upgrade will that be good?
Judging by this quote they are probably wired wrong. What is your VC config on the subs and how are they wired?
Could be weak batt as well
You need to put a volt meter at the Pos side of the amp and read the volts
Also a weak fuse (Not Blown ) will cause this
look for the obvious Low volts to start'
dual and wired straight back from the subs and then joined to one 1 ch. imean theres nothing wrong wit hteh set up i have it right i think its low volts cuz its fine at low volume ist on stock battery??????
Chevyboy10
Chevyboy10
Nashville
subzero
