Subaru Impreza
Petrogk
I have recently been looking at Suabru Imprezas.
I will probably pucharse a 2.5 RS this summer.
I have unfoutunately not had the time to figure out something myself so I have decided to ask all of you.
I noticed that the stock head unit in a Impreza is odly shaped. I was just wondering if a normal, let's say Alpine, head unit would fit in the same place.
I know I may seem lazy, but I have really busy with school lately and any help would be well appreciated.
Thank you all a lot
-Petro Kostelidis
impreza **** when it come to installs due to that you have to take the whole **** thing apart just to put **** in it. like door's and HU . I think if you do get it have a CAR AUDIO PLACE DO IT. Ny friend has one an dit was a ***** to install door speaker,HU and run an AMP. Just letting you know. Good luck if you buy it.
dont go with the flow !
we tried installing a quite simple system (HU with 3 amps, one 5 channel that had 4 front located speakers on it and the boost port was used for a 12"sb, the other amp was a pg/qx 2x50 for the rear speakers, thirth amp was for the "main" sub) which was blood sweat AND MANY TEARS !!!
We did NOT manage to get the system installed in an ordely fashion, it played like mad chicken but cable installation sux, HU inst. is wicked but acceptable but the door speakers are a real disaster...
I wouldnt ruin your car for the audio, get it installed...
I went with Kenwood Exelon. Audio Control amp and speakers. It’s amazing! I’m glad I did some research before buying. Thanks guys.
5
774
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
Nice, well I think they will blow away anything you have running on your puter for sure. I've had good luck with the NVX components, hard to beat...
16
Petrogk
Petrogk
Montreal
phattyex
Dan Medina
    Jun 17, 2024
Doxquzme
    Jun 15, 2024
