Sub woofer wiring
  • 2
Bassscholar
Ohio
Hello audio world I have been roaming the forums for a while but now I actually have a question for you guys! So I have been playing with car audio since I can remember and I can wire speakers up many different ways. Well I just recently got a speaker from a friend who wrecked his ride. Well I took it all apart it was wired all shabby but now that I'm putting it all back together i was curious about the speaker. It has four inputs on one side, and four on the other. Each side has two red and two black totaling 8 inputs. It's an old speaker but it hits hard. The speaker is a planet audio bb2 dvc apeaker. Thanks for any information you guys can give me!!
Looking on google it says its a D4 ohm subwoofer. So it's just for ease of wiring multiples together. Only has 2 leads per side going to the coil so its not a quad coil subwoofer.
Those subs are 400w RMS each, and that dual enclosure is 800w RMS with a 2ohm load. That's a 4ch amp that does 55w x 4 @ 4ohm, & 75w x 4 @ 2ohm...
814
Many moons ago I was heavy into Car Audio Systems(Iasca stuff) but a ton of things have me removed and knowledge forgotten so I need a refresh. I...
Well.. Not sure you could wait that long.. But the 4th is coming? might be the time snag them up then? i wouldnt think they would perform too bad...
127
333
416
Bassscholar
Bassscholar
Ohio
    May 12, 2024
Brendon Jenness
    May 11, 2024
