sub wiring question thats been buggin me
limbs760
sandiego
so everyone is saying u cant wire 2 dual 4ohm subs to 2oms , but my hifonics brz 1700.1 is a mono block amp with 2 slots to put speaker wires (+-+-) so my question is can u wire a single dual 4ohm by itself to a final 2ohm load? speakers are gonna be wired independantly to 2 ohms to the amp will it still be a final 2ohm load? on 2 dual 4ohm subs? i know it sounds confussing let me know thanks for all the help.
My question is, why do people keep posting questions like these in the classifieds?//content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif
wow so my kicker cvx's are getting under 300 watts a piece and this whole time i thought they were at 2 ohm load which is 1200rms at 2 ohms thanks for the help guys and my bad on posting this here guess i be wiring these puppys to 1ohm at 1700 watts
Here you go that's for one
Yea, it's still a 4 ohm load. Don't be confused by 2 positive and 2 negative terminals. It's still a 1 channel amp. It has 2 sets of terminals for ease of wiring so you don't have to cram 2 sets of speaker wire into a single terminal.
they are dual 4 ohm but not wired to 1 ohm the guys who hooked them up wired the subs individualy to 2 ohms then hooked them to my mono amp so i think they are at final 4ohm load.
A little DAP will do ya, drill, feed & seal, done.
633
two d2 subs can be wired to .5 or 2 or 8 ohms not 1 heres how to wire subs...
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
This might be easy for some but i've only had it wired as a 4 channel. Theres a 2 channel to 4 channel switch and 4 rca's on the other side of the...
Having to adjusting the sub input sensitivity depending on the music, would be reason enough for me to go with the RCA cables. It does seem odd...
limbs760
limbs760
sandiego
Bomtillington
    May 16, 2024
    May 16, 2024
