sub wire
The wire to the subs usually needs to be of a heavier gauge since resistance of the wire will increase with length. The tinsel wire is short enough that it's smaller gauge is ok. The "Wire Guide" sticky here has some recommended sizes.
i have 8 awg now i went to my local shop last night after work to get sum bc the stuff i have was super old and cut to crap i when i asked for it they said they didnt sell any wire under 12 awg bc no sub would have enough kenetic energy for that size wire..and that they had neve heard of any one using the power wire for a sub lol
they obviously have never heard of spl then lol
how long is the run from your amp to your subs? if its short you can get away with smaller wire... or u can always use multiple runs if you cant find anything as big as u want
They used the term "kinetic energy" for that? heh. Anyway, how much power is going to your subs at what ohm and about how far is the run? The sizes listed under "Speaker Wire" here will be fine:
http://www.caraudio.com/forum/showthread.php?t=166038
8 gauge is overkill unless you have some tremendous power at a low ohm load. Power wire can be difficult to work with at those sizes, I would use something with more strands. You can probably find the wire you need online for less than that shop too.
thanks ya ive seen the chart was just wondering if u could do the same size as the tinsel but didnt think about how long the tinsel is , 1200rms @ 2 ohms, about 3 feet runs, and ya he said kinetic energy lol
With such a short run 12 is probably ok but I would get 10 to be sure, short runs won't cost much, and it can even handle the kinetic energy //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
NewToTheGrounds
NewToTheGrounds
Canada,ON
Stel
