Sub Stopped Working
I got 2 12" Kickers in the back of my car, they were both working last night at about 2 AM, when I got in it again at noon today only the one is working. I wasn't messing with any settings or anything, does that mean it has to be a wiring issue? Any other possibilities? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Try to push in your cones.
Is the one that doesn't work not move?
Or is it hard to move?
It's possible your subs unloaded all the power on your subs and one took the blunt of it and blew.
Try to push in your cones.Is the one that doesn't work not move?
Checked, the one that bumps and the one that doesn't push in the same. //content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif
Take out your subs and look at the spider (the part right under the cone.) Check if there's any burnt residue... While you have the subs out, switch the outputs.
It could be your amp that blew.
Take out your subs and look at the spider (the part right under the cone.) Check if there's any burnt residue... While you have the subs out, switch the outputs.It could be your amp that blew.
Could the amp be blown if one of them is still bumping?
Also when I took it apart it looked as if some of the wiring was pretty flimsy, and actually fell off when I touched it. I'm going to rewire it this morning after class to see if that works.
I found that one of the fuses was blown, which would seem to me to be the problem but when I plug the other fuse in the blown ones slot the sub still doesn't work.... //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
MountyMoonshine
MountyMoonshine
Country Roads, WV
MountyMoonshine
