Sub only sounds 'loud' when music is played through my galaxy s4
LongThrow
My Kickers be swaggin'
Pioneer deh150mp head unit.
I have to have SLA up to +4, LPF subwoofer level to max (+6) gain on amp set to 65%, eq 80hz on hu to +6, loudness on high. THEN I have to use the new setting on my phone to increase more low bass note freqs., and then a separate bass adjuster on my phone. With anyone else's phones, or eq set to normal on my phone, the bass is still there but not 'loud' or 'heavy' like it is when I have it EQed to hell.
10 inch kicker 150watt 4 ohm in prefab truck box
Sony xm502z believe around 125w x 1 4 ohms stereo/bridgeable
8g boss wiring kit
All connections are great, 'professionally'(local audio installer) installed
The problem is in the amp.
If you have to bring all the gains up to get near what you want then it is because you do not have enough amp power to amplify the signal from the headunit.
Find a 2 ohm stable that is atleast 100+ more watts then what your sub is rated for so you have overhead to turn it up and get more power for your sub.
But with a 125 watt sub you cannot expect much since alot of components mids can handle 150 easily.
Your pretty much using a very very very weak sub.
Its a ported truck box but nevertheless I still need to upgrade. I'm just gonna sell the system I currently have. Just be happy with my pioneers and power my door speakers with my amp (I have 2 of the same amp) and then just save up for a real system.
Ported prefab truck box=crap
457
483
592
LongThrow
LongThrow
Springfield, MO
LongThrow
maylar
    Jun 2, 2024
    Jun 1, 2024
