sub mounting?
JohnnyP
'69 Charger Owner
23
Cary, NC
would it be alright if i only had about 1 or 2 inches between the sub and the trunk lid? the 1-2 inches is after the ton of dynamat that i have to put on the lid, before the mat there would be about 3 inches? also if i build a box with the dimension of H= 15", W=40", depth or length=25", and top mount the sub, how would i port it and tune it? one more thing.... would it be ok if there was only about 1 in between the bottom of the sub and the bottem of the box? because there is a hole in the center of the magnet i am assuming for air movement?
i dont know to much about solox's but i know there the most badass kickers you can get.....and i think you would need more room then 1-2 inches because personally i think that baby would come out pretty far
after all variables or what ever are taken out there will be only about 1-2 in between sub max ex and the trunk lid
Holefully he doesn’t hook batteries in series thinking it halves the voltage…..
29
I would put two Eyelets on front and back close to the bottom of the enclosure with Toggles, rubber washers, and metal washer to seal the...
204
358
442
JohnnyP
'69 Charger Owner
JohnnyP
Cary, NC
JohnnyP
    May 12, 2024
Brendon Jenness
    May 11, 2024
