Sub making an awful popping/rattling sound.
tehlicky
Hey everyone i don't know a whole lot about car audio but i have a question for who ever can answer, I installed my subs around a month ago and they worked perfect up until a few days ago. The problem is that i bought a box with the subs installed and one of the 2 subs is making a rattling/popping noise but i'm not sure what it would be causing this. (like i said i don't know a whole lot about audio) I've asked some of my buddies and even they aren't sure, i thought it was blown or something but they said its not blown so i just wanna know if there is a way to possibly fix this before i just replace it, they were pretty cheap so i don't care about replacing but if anyone could help it would be pretty huge. I'm running them on a 500watt mono alpine amp. The subs are 2 12 inch jensen subwoofers.
could ba many things, typically, that sounds like a half-broken tinsel making intermittent contact, but could also be a loose joint somewhere. does the cone move smoothly when you physically push on it?
264
425
529
In that airspace you could go ported with th Si SQL 12@$369, hands down the best option in a 1.41 ported box. With 1000 watts RMS and 92 db...
16
847
537
tehlicky
tehlicky
Saskatchewan
akheathen
    May 18, 2024
    May 18, 2024
