sub issues
  1. npal_77
    Sub amp issues
    Hey everyone, So I just recently switched my sub and amp to a car I just bought. It's a 05 Acura TL, which has a stereo that's difficult to remove and retain all channels/speakers. I tapped the stock subwoofer remote wire, ran that and my power to the back, tapped the stock sub's signal and ran...
  2. J
    Sub or Amp Problem?
    Hey everyone. I have a new problem with my system. I changed amps 5 weeks ago, and it has been sounding really good since. Then all of the sudden, the speakers on my left side went out (not too worried about that, because it has happened before) but my subs started acting funny. The subs will...
  3. C
    Sub making noise when car turns on.
    Hey guys new to the forum here and I am by no means excellent at wiring or sound systems. First of all I have a 09 Honda Civic si, and I installed my old amp and subs working system into this car bout a year ago. Still using stock head unit. So the issue is when I turn my key whether to on or...
  4. P
    Help
    I have a db drive dual 600w max sub box and an okur 1000.1 amp, I have had this same setup for about 2.5 years. Recently the amp had been going into protection mode I checked all the wires, fuses, connections, and for corrosion, but it kept going to protect. I played the amp by itself for a few...
  5. C
    Trouble playing higher bass notes - 60-80hz
    Hi, I've been having a problem with my setup and any information would be appreciated. I have a basic setup, aftermarket head unit, amp and sub in my '02 Grand Am SE. I like to listen to dubstep and trance music mainly. The dubstep sounds great with the heavy low notes, but with dubstep and...
  6. Wolfenit415
    From 4 ohm to 2 ohm back to 4 ohm resulted in loss of power.
    Hello, new guy here. Thanks to anyone who takes the time to read this and post a reply, it is much appreciated as I'm racking my mind for the last 2 days. To make a long story short, i recently bought a budget system. This system includes a Rockford Fosgate R250X1 Prime 1-Channel Mono Block...
  7. T
    Amp kicks out at any bass. Whats the problem
    i dont know if the problem is the amp or the woofer. i hav a pioneer gm500t a boss cap10 and a Kenwood KFC-XW12. but the kenwood isnt the problem. i had the amp connected to a BOSS P126DVC 12" 2300W PHANTOM. could i be asking for too much from the amp with the boss sub? i had the boss sub...
  8. T
    Sub making an awful popping/rattling sound.
    Hey everyone i don't know a whole lot about car audio but i have a question for who ever can answer, I installed my subs around a month ago and they worked perfect up until a few days ago. The problem is that i bought a box with the subs installed and one of the 2 subs is making a...
