Sub for my amp...
Besbro
Hello,
I am going to be installing the following Cadence amp:
TXA-6004
150 x 4 @ 4 Ohm
300 x 4 @ 2 Ohm
600 x 2 @ 4 Ohm
I will be using two of the channels @ 150 RMS to run my front stage. That leaves me with 300 x 2 @ 2 ohm or 600 x 1 @ 4 ohm. Does this mean I can go with a svc 4 ohm if I bridge the two channels together or a dvc 2 ohm sub and run the 300 x 2 @ 2 ohm to the sub? I do not understand how this works.
I was interested in a Type R but they are dvc 4ohm i believe? Does this mean a Type R will not work for me?
On a side note I am considering a 10" type R, a Cerwin Vega V-max or a Dayton Ref H.O. I am going for SQ but I would like a little "punch" to it also. Would these be good choices for me, I am having trouble deciding on one. I would like to know if the Type R is even an option for me though....
Thanks in advance for any help you can give a newb...
Besbro
Besbro
Winnipeg Manitoba, Canada
Besbro
