sub fastener question.
Most people use T nuts to create a threaded insert. Just drill out a hole big enough for the T nut to fit in and then press it in the hole from the opposite side. Then use the bolt you bought that has the same thread design as the T nut to fasten the sub to it.
Most people use the screw to help "pull" the T nut into it's hole/final resting position.
Here is a pic of what i'm talking about. You can get them at lowes in the fastener section. They have tons to choose from.
threaded inserts worked great in my case. you drill a pilot hole, then thread them into it with an allen. mine are 1/4-20. it's a pretty heavy sub though.
t-nuts tend to strip out, hurricane nuts are a bit better, but threaded inserts seem to be the best way to go. how heavy of a sub are you talking?
I used t-nuts on my last install and they seem to work fine. only problem is its hard to keep the back but in place after you put the speaker in...
ie: when u try to push the bolt through to screw it in sometimes it will push out the nut if its not in there tight enough.
audioarsonal
JaMarcus
audioarsonal
close to home...
audioarsonal
Mike Mccabe
