Sub Depth?
David411
How much space should there be between the rear end of the sub and the back of the enclosure? I thought that the only spec that mattered was the total volume. I am mounting an eclipse SW7200 12" Sub. My friends tell me I need 5-10 inches of space between the sub's rear end and the box, I currently only have 2 inches of space? Are my friends right?
If you need between 5" & 10" between your sub and the box then no one would be able to put a sub under the rear seats of their trucks...so what do you think the answer to that is?
as little as an inch is fine in most cases
David411
David411
Edmonton, AB
ProgMtl
