SUB DAMAGED Help please
billy18bm
well i have an audiobahn alum12q well 2 actually but one of them just all of sudden stopped working and i took it out and part of the spyder came loose from the cone and it dosent even turn on at all could this be the wire going to the coil or is it jsut because its ripping becuse can i just use some epoxy and glue that spyder back ... also ive only had the sub from audiobahn for about 1 month and a half and its already broke is it under warranty and how do i contact them.. also will it damage my other sub with my 3000 watt amp going to it??... tahnks for all the help..
Contact Audiobahn directly. If you do not have any warantee contact info, just find their website, call the main number, and ask. Im assuming this was an internet purchase as you haven't mentioned taking it back to any local shop.
The spider coming loose from the former should not make the sub stop working altogether. Most likely the sipder came loose, allowed the coil to go drastically non-linear, and the coil shorted out. Either way you need a recone if Abahn offers such a thing for it (prolly not), or a new sub.
Whether or not it will damage your other sub depends on some things, like if they were in a shared chamber box. For safety sake I recommend you shut down your subwoofer system until you have it working properly again.
billy18bm
billy18bm
Indianapolis
audioholic
Mike Mccabe
