Sub Boxes
  • Thread starter Unregistered
  • Start date
  • Replies 3
  • Views 534
  • 1
U
Unregistered
Guest
Does anyone know if the cubic feet of air space changes between ohms? I mean, does ohms even matter when it comes to air space? Cause I have a 4ohm sub but I could only find specs for the same sub but 8ohm online and i was wondering if they would require the same amount of air space or if the amount of required air space changes w/ ohms?
thanks
I don't think that matters. The only thing thats different is the resistance of the voice coils. but i'm not an expert in this area. i'm just assuming.
Ohms and airspace have little to do with each other directly. Indirectly they would effect each other. However, if what you are asking is- "will a given 4 ohm subwoofer work in an enclosure stated for the same given subwoofer only an 8 ohm model?" Then the answer is yes, it will.
take it easy,
-zane
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
930
198
539
568
Guest
