sub box wiring ? please help
mm0142
CEO
ok i have a box its 4cft and slot ported tuned to 33hz like my 2- 12" re se call for . my ? is it has the slot in the middle can i wire one sub and go through the back , around the slot port and back in on the other side so i can wire bothsubs to 1 ohm to run on my amp ? i just wasnt sure it the long distance between the two subs wiring would be an issue or not . thanks everyone im just trying to do this all right then ill post pics . if itsan issue howcan i wire both subs to 1 ohm they are powered with a sundown sae1200d
Should be an issue, though I would suggest drilling a small hole through the port. Maybe drill it against the back wall and run the wire through and seal with silicone. The wire may move around in the port and make some noise.
if the distance will be an issue i will jsut build another box instead of building this one but i cant find the plans for a 4cf slot ported box for dual 12's tuned to 33 hz . any help will be greatly appreciated
preferably with one chamber for the 2subs and a slot port on each side of the box size isnt an issue itsgoing into a tahoe anyhting 47wide by 22high and any depth is ok
mm0142
CEO
mm0142
Waco, Tx
SicAudio
