sub and amp wiring question
RobertFielding
this is prolly an easy question for you guys but im a little confusesd, ive got 2 infinity 12.1 subs and im going be getting a jbl gto 600.1 amp. the amp puts out 580x1 at 2ohms, so im going to wire my subs to 2 ohms, the positives together and the negative togethers, now im like with 1 positive wire and 1 negative wire going to my amp, which i beilive is now a 2 ohm load, the amp has +-+- but i only got 2 wires, 1 + and 1 - where do i place them. thanks
if your subs are single 4 ohm subs, then that is a 2 ohm load.
It doesn't matter which terminals you use on the amp, as they both go to the same place. There is only 2 sets to help with wiring.
RobertFielding
RobertFielding
Windsor
ultimate157
