stupid idea?
kizz
I have a '97 dodge stratus. right now i have one ten inch memphis pr sub in a .75cubic foot sealed box. i have had an idea for a while to put two tens in the rear deck where the 6*9s go and mount a box underneath. I know i will need to cut and brace and what not. Just wondered if it was a bad idea. also i plan to make the box ported and im not too happy with the memphis so what would be a good replacement? im looking at no more than 140dol. a piece for the subs
this=FAIL
No it isn't...
However, what I would do, personality, is cut out the rear deck (the thin metal, not the stuff that actually supports any part of the car) and make a recessed sort of box, so you can put grill cloth over it so no one can see it.
But a lot of people do this with great results.
But, to get an even better / louder response, you could seal off your trunk from your cab so there's less air to pressurize.
I have thought about sealing off the trunk as well, might actually be an easier project. so if i seal it off, where should the port be facing? into the cab as well?
ok then, last question that wasn't answered. What to replace my memphis pr's? i haven't tried them in a ported box, that might help, but they just dont seem to be able to handle much. they distort easy and cant take real low bass.
at the moment im only powering it with a kicker 4 channel amp. i bridged two channels together for it 175 watts rms. i plan on getting a hifonics amp of some sort when i get the funds
kizz
kizz
omaha, ne
kizz
