Stuck between a few different 18's... Psi, Fi, Aq?
akillj
CA
I'm doing a daily build, space isn't an issue. Will be ran on 2k. I'm looking for something that will smash the lows as loud as possible in the 30-40hz range, with extension into 25hz range.
I've been looking at a few different subs, I don't want to go over $400 on the sub. Anything I buy i'll get all the extra options on.
PSI Platform 2 18''
FI BL 18''
FI Q 18''
AQ HDC3 18'' (Copper coils)
I hope i've given enough details.
That's what I was thinking, but I was leaning towards the AQ just cause of how loud it gets. But I'm concerned as to how "low" it will play, in say 6cuft @ 36hz. I heard they like to be tuned high, but my concern is that this will make it sound peaky, then drop off below tuning.
Defiantly. LOL 😂 It has never happened to me👀:poop:
498
No. Unfortunately, this seems to be a common issue with the Jensen Car1000. I have one that is less than a year old that gets stuck some days. I...
When you random through your music library, you know you got your gear dialed in nicely.
18
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
akillj
akillj
CA
naughtyca
    May 16, 2024
    May 16, 2024
