Struggling... Need Help!
amtrucker22
20
FL
Here is what I installed:
MA - M500XE
Specs:
1000W 4 Channel High Performance Amplifier
4 x 125W RMS @ 4 Ohm Stereo
4 x 225W RMS @ 2 Ohm Stereo
2 x 500W RMS @ 4 Ohm Bridged
Kicker Comp VR 12's
Specs/wiring choices
Parallel wiring
Dual 2 ohm = 1 ohm load
Series wiring
Dual 2 ohm = 4 ohm load
I have it setup right now with the MA amp at 2 x 500W @ 4 ohm bridged and the Kickers setup in series.
The speakers do not get that loud with this setup. Is there another way that I could set this up to make it get louder? Or is this just a bad amp/speaker combo?
This is going into a dodge ram quad cab with 1 chamber and 1.8 cu feet of airspace.
Thanks,
Paul
MA - M500XE
Specs:
Kicker Comp VR 12's
Parallel wiring
Series wiring
Thanks,
Paul
You have 1 or 2 subs?
amtrucker22
amtrucker22
FL
NeverEnuffBass
