strapping saz1500d's
MTXThunder9500
Fo Shizzle
hey guys im working on a new stereo for next year and i was wondering if i strap two sundown 1500d's together at .5 ohms each so its a total of 1 ohm total what can i expect to see out of them? im looking for 4000 watts at least and im just curious.
also will a 200 or 220 amp alt and either some kinetik's or tsunami batteries be enough?
one other question someone told me taht FI's BTL's are acutally dual .7 ohms and dual 1.4 ohms is that true? and then my next question is i should probably do two of the dual 1.4 ohms instead of the dual .7 ohms so cuz if im correct the amps will see .35 ohms then if i use the .7 ohms right??? Can the sundowns take taht low?
The actual impedance the amps will see depends on your enclosure...hard to say what it'll actually be unless you test it.
so the safe bet in other words is the dual 1.4 then hahaha. but when the amps are strapped what can i expect to see then in series and also in parrell
MTXThunder9500
Fo Shizzle
MTXThunder9500
Fargo, ND
scplayboy00
michigan born
    May 14, 2026
michigan born
    May 14, 2026
