strapping 40.1's
TnT_Sounds
profiling gets **** done!
I have 2 40.1's I intend on strapping them since I will be running 6 15's. Now I did some math and I was only able to come up with this for 6 15's,
series
6-D1 coils= .5ohm
6-D2 coils= .7ohm
parallel
6-D1 coils= .125
6-D2 coils= .167
Someone please correct it if I'm wrong but I dont think I can strap the amps up in either formation
Or do I not calculate all 6 subs together?
I'm confused:confused:
I'm not sure which subs you're using but if you have some power to spare you could split them up so each amp is powering three D2 subs @ 1.34 Ohms each. Otherwise, you have to calculate all 6 subs if you were to strap them since they would initially become 1 mono amplifier.
-Bill-
you wire 3 D2 down to .67. and 3 more D2 down to .67 so now you have two .67 ohm loads. wire that in series so now you have a 1.7 ohm load... strap that and each amp sees a .85 ohm load //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
how about 4 D4's together wired in series/parallel for a 2ohm load? That would put a 1ohm load on each amp correct?
Get 4 D2s, strap at 1ohm, .5 each amp.....easy peasy lemon squeezy
already have 4 D4's //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Did them so I can later get SD 5000's and run 1ohm on each pair. I also know from experiance the 40.1's dont like my type of daily abuse:crap:
Man they played in my friends car daily at .35, what were you trying to do?
Wasn't trying to do nothing. I have a different definition of daily. I also demo for a couple hours straight. They didn't like .34 DCR for more than 10 minutes
TnT_Sounds
TnT_Sounds
Colorado
TnT_Sounds
Mike Mccabe
