Grounding RCAs to reduce whine?
TheJuggla1
I saw in the stick and going to try this I have 2 questions
first; why are ground loop isolators so frowned upon, I know it just 'covers up' the problem, but how is that bad?
second in the picture he has the 2 lefts and 2 rights grounded separately, do I have to do this? Or can I ground them all off one wire? Will my deck having 6 RCAs have an effect on this?
u can use one wire but its easier for seperate wires. and 6 rcas?? u mean 3 sets of rcas? unplug them all and plug one in at a time then and find out which one is causing whining then ground that one
Ok I just went ahead and ground them all, isn't like it was much more work. One more question is as you see in this picture
http://i22.photobucket.com/albums/b342/Ultimate157/PioneerFix.jpg
they guy grounded them to the screws away from the RCAs I grounded mine to the middle screw(In the picture they screw between all 4 RCAs) is that the wrong screw? I couldn't find a screw driver small enough to remove any other screws.
dude check your radio antennae plugin in the back of the headunit, that will cause a shitload of alternator whine transmission, i just moved mine far away from all of my speaker wires/rcas/and remote turn ons and it solved my problem with my alpine
Oh maybe that is why, I just left mine to sit on the HU
TheJuggla1
TheJuggla1
Surrey BC
McIntosh
Mike Mccabe
