Strange Feedback Issue
tsunam1
Feedback in Right front speaker - only when car is on - only when Subwoofer RCA's are plugged in. When i push on the gas pedal I get a 'squigly' sound - when the engine is running i get a high pitched buzz.
I regrounded the head-unit and the speaker / rca's run on the opposite side of the car from the main power line.
Any ideas?
I doubt it has anything to do with the rca's. they are low voltage and low current so little opportunity for coupling.
maybe your sub amp ground.
kent
I grounded the RCA's and there was a very slight improvement - barely noticable. Any other ideas? I've tried running the RCA's directly (not hidden) from the head unit to the amp with no improvement.
I tried re-grounding the amp. I'm going to run a new power wire directly to the battery. Do you think grounding the RCA's on the amp would help?
I forgot to mention - the feedback is now in both left and right speakers and you can hear it even when the car is off. There's still a squiggly noise when i touch the gas pedal
Ok so i finally figured it out. BOTH RCA's must be running over something causing the feedback. I first attempted to run one RCA through the cabin freely. I replaced one RCA at a time and had the same problem. The strange thing is I only get feedback when both RCA's are plugged in?
This time ran both RCA's freely through the cabin and had no feedback = D
Problem solved though i wasted a ton of time troubleshooting.
kent
They are a low level signal, which means it doesn't take much interference to become a large percentage of the signal being transmitted, which is then amplified, interference and all.
RCAs and related hardware are quite often the culprit when you have an engine whine.
tsunam1
tsunam1
Ontario, Canada
Kyle!
Mike Mccabe
