Stop the buzzing!
foreman
NY
Ok, i need help here. I've been installing gear on and off over 14 years and i've never encountered this. I hope it's simple and i just missed something....I have a Panasonic CQ-dvr909u deck, and i have feedback coming through the speakers. It sounds like humming, or a buzz of sorts and changes very slightly with idle., not alt. whine, at least not high pitched.I've tried 4 diff. amps, and 2 different decks, and diff. rca's. The noise stopped with a low-voltage entry level sony, but a high end old school kenwood with 4v preouts, same thing. I have the amps grounded to the bolt on the rear strut tower...by the way, veh. is a 93 accord EX. Help!..............
Reground your deck the factory ground in the harness on hondas are almost always crap. So try grounding your head unit directly instead of through the factory harnesss.
I have read about this, and honestly the installer did nothing wrong. It's the newer vehicles that have the automatic engine stop/start (instead...
983
Those subsonic frequencies make a difference in how music sounds. Hearing the music and also feeling the subsonics adds a depth to music. You hear...
10
I just learned a couple of days ago that shark fin antennas are powered. Your issue may be related to that. Either the power to the antenna is...
Just want a give an update. I ended up trying a capacitor to see if it would work before spending on a battery. The capacitor does work, the...
It might be "ghetto" by today's standards but I used to run a wire off the battery to a switch then to the amp...back in my youth the Police liked...
15
4K
foreman
foreman
NY
Pete
    May 16, 2024
    May 16, 2024
