stinger vs. kinetik
Another thread???? Jeezus........... Get a 2400 up front and an 1800 in the back. Or get an H.O. alt and a 2400. Either fukin do it or don't do it. Stop being cheap and trying to cut corners. find the cheapest priced 2400 and buy it. That's what the calculator said. If you don't want Kinetik, but the equivalent of that then.
Here is how Turd would do it.........
Yellow top up front, 2400 in the back. Your Xplod 2 channel and your L7s would not cause dimming.
dang
So did you sell the Xplod locally? If you still have it I would like to use it and sell my AQ2200D.
The thing is Ranch, you want either a new product at a used price, or a used product that looks new at a dirt cheap price.
I would honestly do a Yellow Top up front and a 2400 in the back. You're not even running 2500RMS. You said you did your big 3. That would work for you.
i am running 1500rms of subs from the zx1500
and then another 350rms at the moment from the zx850 and in the future will be adding another set of second comps so 2200rms will be total
if i run with my 130amp alt, big 3 done, and gold duralast upfront for now and put the stinger spv70 in the back can i run and not worry bout voltage issues, i was reading that the spv70 is close or better than hc2400
Dude..........
Fused power and a ground run from the front battery to the back. Don't be a cheap *** and do it in 8ga or something. Do it with 1/0 wire. Depending on who you ask, the power from the front to the back needs to be fused 2 times.
So simple even you can do it. You'll need some kind of enclosure though as well.
king ranch
Banned
king ranch
fl
ssackett
vegang
vegang
