stinger sgp32 isolator
stilltippin863
ok..i just ordered a sgp32 stinger isolator i was wondering how do you hook it hook??
the power wire from front to isolator and then from isolator to battery in trunk???
what are the small terminals on it ?? both grounds ?? and if so do they both have to be grounded??
and should this unit be closer to back battery or front battery?
I don't think the small terminals are grounds...
What does the isolator look like?
The multi-battery isolator contains several diodes,
mounted in a heat-sink.
(diodes are like one-way-valves for electric current.)
The dimensions are approximately 4" x 4".
It has 4 terminals.
No. 1 terminal is connected to the main battery.
No. 2 terminal goes to the second battery.
The A terminal goes to the alternator output.
The R the remote sensing terminal goes to the regulator.
Constant 12V+ Brown or Yellow or Light Green Ignition Switch Harness
Starter White/Pink Ignition Switch Harness
Ignition Brown/Pink Ignition Switch Harness
Ignition 2 Gray/Yellow Ignition Switch Harness
Ignition 3 Pink/Brown Ignition Switch Harness
Accessory Black/Light Green Ignition Switch Harness (AC/RUN)
which one is the true ignition power so i can tap into it to run to the isolator?
Whichever one that reads 12v only when the car is on. Get the DMM out and start searching!
Unless you have a diagram or something, ideally you'd want the wire that goes straight to the ignition.
Whichever one that reads 12v only when the car is on. Get the DMM out and start searching!Unless you have a diagram or something, ideally you'd want the wire that goes straight to the ignition.
that is the wire i am trying to find
i got all this for my car so..... i think brown,yellow,or light green are the ones but i guess i will have to check to see witch one comes on with the car and shuts off when i cut the car off correct? you do not want a constant power going to it at all times?
2000 Mercury Grand Marquis Alarm, Remote Starter, Keyless Entry Wiring Information
Tach Light Green/White PCM Pin 26
Neutral Safety Wire Not Grounding OEM Switch opens Starter Circuit
Brake Switch Light Green Brake Switch or 16 Pin Connector Driver's Kick
Trunk Release Purple/Yellow (+) 3 Pin Connector Driver's Kick Panel
Trunk Pin Brown/White (+) Light in Trunk
Parking Lights Brown (+) Light Switch or Driver's Kick Panel Black Connector
Head Lamp Red/Yellow (+) Passenger's Side of Steering Column Light Module
Factory Disarm Green/Purple (-) Driver's Door Boot
Door Trigger Black/Light Blue (+) Light under Dash
Door Lock Pink/Yellow W/Keyless Positive Trigger Driver's Boot
Door Unlock Pink/Light Green W/o Keyless Entry Reverse Polarity
Driver's Lock Pink/Black (+) Dark Door Jamb Boot
Driver's Unlock Red/Orange (+) In Driver's Door
Passenger Unlock Pink/Orange (+) Dark Door Jamb Boot
Horn Wire Dark Blue (-) Steering Column
Windows Up LF=Yellow, RF=White/Yellow, LR=Gray/Orange, RR=Red/Black
Windows Down LF=White/Black, RF=Tan/Light Blue, LR=Yellow/Blue, RR=Yellow/Black
what you guys think about this one?here
That is about as good as you will find. The largest I could find in the diode based units was around 200A, like this one. What I did learn is that you can parallel them just like batteries if you need more than 200A of throughput.
Just an FYI though, you will see a small drop in voltage using this style of isolator, so the MLA adapter or an external regulator would be helpful to offset the voltage loss.
stilltippin863
stilltippin863
Florida
stilltippin863
