Sterero not working
You have a sub connected to your 5 channel amp?
A wiring harness will not cause this if the headunit is working unless you mean there is a wire harness on the amp?
It would be easier to take a photo to show how your setup is installed.
Even if it started playing for few minutes? Been messing with all evening and got it to play correctly for a few minutes then it went off again.
Is it going into protect mode.
Also lower all the gains and make sure all speaker wires are connected to the correct spots and also check all speakers.
Nhb21
Nhb21
San Angelo, tx
Savackz
vegang
vegang
