Stereo Integrity 18s $165 shipped each
2000LaDe
1. Product:
Stereo Integrity HT 18 dual 2 ohm
got 28 of them
2. Specs:
600 RMS
18" D2
Re: 3.5 Ohms
Fs: 17 Hz
Qes: 0.41
Qms: 5.8
Qts: 0.38
Le: 3.2 mH
Sd: 117841 mm^2
Vas: 411.9 l
BL: 19.7
Mms: 416 g
Cms: 208.8
Sensitivity (1W/1m): 88.7 dB
Xmax: 22.5mm
Recommended enclosures: 18"
Sealed = 4 ft^3
Ported = 5-6 ft^3 tuned to 20 Hz
Cutout: 16.7"
OD: 18.5"
Mounting depth: 9.5"
Mounting flange to top of surround: 1.5"
Displacement: 0.25 ft^3
3. Description/Condition:
New In Box. got them for a big build had different priorities come up
4. Price: :
$165 shipped lower 48
5. Pictures:
for whoever ended up purchacing theese i figure this link is good info on them if you wana do some homeworkData-Bass
and
Data-Bass
after finding those links and reading up on them i decided to go with 4 also they should be pretty good ib capable on low power
On this link it says it is more suited for home audio, is there any reason for that? Will it be fine in my car?
what i got from those links is that this woofer has the ability to play down to 20hz with verry little distortion compaired to other drivers - and will still have a -3db response all the way up to 400 ish hz
so if you are one of the weirdos like me that set the subsonic filter in the 200ish range then this will play mid and sub bass maby mess with my 6ch eq a bit to blend the 2 together nicely but i see no reason at all this wont work fantastic in a car on "low power" up to 600w but could also probably be sound q oriented running on a old ab class amp bridged at 4 ohms on 300/400w
its not 100% nessary to run systems with 5 digit wattage numbers, extra batterys and alternators to satisfy the needs of bass in a viechle
what i got from those links is that this woofer has the ability to play down to 20hz with verry little distortion compaired to other drivers - and will still have a -3db response all the way up to 400 ish hz so if you are one of the weirdos like me that set the subsonic filter in the 200ish range then this will play mid and sub bass maby mess with my 6ch eq a bit to blend the 2 together nicely but i see no reason at all this wont work fantastic in a car on "low power" up to 600w but could also probably be sound q oriented running on a old ab class amp bridged at 4 ohms on 300/400w
Any idea if they get loud? My old system was a 12" Type R on 500 watts. If I put this thing on 600 watts will it be a lot louder? Or is it just SQ?
This question gets asked WAY TO MUCH!
In theory it should be louder BUT it will only be as loud as the box you build.
All the components(though I think the tweeters are oos) the sql10 and matching passive radiators are on discounted preorder too
10
Those pair of 12s with the right enclosure and tuned as well as powered properly should perform much better than the single 15, provided you have...
  • Locked
Well I think mounting depth with be shorter on the BM 11, and of course surface area is more on the MKV 12. The 11 is more of a niche driver than...
While we call the M3 Carbon our midrange it is actually a wideband loudspeaker capable of playing from 125 Hz up to 20,000 Hz. We recommend a...
2000LaDe
2000LaDe
Lafayette, IN
brian84corvette
    May 16, 2024
    May 16, 2024
